georgia mike
- 1
- 0
- N. Georgia
This past fall I installed 8 new AC Delco 60g glow plugs in my '86 M1008. Everything has been fine up until a couple of weeks ago when the truck began to get harder to start. I checked the glow plugs with mixed results. Most checked fine; a couple checked no good until I pulled them from the heads. Weird for sure. Anyway, I checked the voltage coming off the GP relay, as well as at the plugs and I'm only getting 11 volts. Batteries measure ~12.5v each static. It should also be stated that the PO installed deep cycle batteries in this truck (well, the rear one says marine deep cycle, the front says marine starting). I know these types of batteries aren't meant for automotive use, so these will be going to my boat soon and will be replaced with a pair of group 31's.
So I guess the meat of my question is: Is 11 volts too low to reliably heat the 60g glow plugs?
