these are my readings.
1. Truck ignition off, truck not running.
25.03 A. Voltage at the positive terminal should be approximately 24-25 Volts.
25.03 B. Voltage going into the resistor bank should be approximately 24-25 volts.
25.03 C. Voltage coming out of the resistor bank should be approximately 24-25 volts.
25.03 D. Voltage at the top of the glow plug relay should be approximately 24-25 volts.
00.00 E. Voltage at the bottom of the relay should be Zero volts.
2. Truck Ignition on, truck not running, in glow cycle.
24.7 A. Voltage at the positive terminal should be approximately 22-23 Volts.
24.7 B. Voltage going into the resistor bank should be approximately 22-23 volts.
24.7 C. Voltage coming out of the resistor bank should be approximately 10-13 volts.
![Crying :cry: :cry:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
24.7 D. Voltage at the top of the glow plug relay should be approximately 10-13 volts.
24.7 E. Voltage at the bottom of the relay should be approximately 10-13 volts.
3. Truck Ignition on, truck not running, not in glow cycle.
24.7 A. Voltage at the positive terminal should be approximately 24-25 Volts.
24.7 B. Voltage going into the resistor bank should be approximately 24-25 volts.
24.7 C. Voltage coming out of the resistor bank should be approximately 24-25 volts.
24.7 D. Voltage at the top of the glow plug relay should be approximately 24-25 volts.
9.69 E. Voltage at the bottom of the relay should be Zero volts.
Left the ignition on for 2:15 seconds still had the 9.69 bottom relay reading i then tried to start it batteries seemed very low.
Ruben C Ramirez Sr
