1984 m1008 cucv does not start
Minister956
Florida
Done that.
19. ENGINE CRANKS BUT WILL NOT START; ENGINE COLD; “WAIT” LIGHT OPERATES
Step 1. Ensure that key is in “OFF” position. Check for voltage between glow plug relay
terminal where orange lead connects and ground.
If there
IS voltage, replace glow plug relay (see paragraph 4-8) and perform
step 3.
If there is no voltage, perform step 3.
2-64
MALFUNCTlON
TEST OR INSPECTlON
CORRECTIVE ACTlON
CAUTION
DO NOT leave key in “RUN” position for more than 2 minutes. Failure to
follow this caution may result in damage to glow plugs.
Step 2. Turn key to “RUN” position. Check for voltage between glow plug relay terminal
NOTE
Glow plugs will cycle to 0 volts in approximately 20 seconds after first
operation. Time will shorten as glow plugs become hotter.
If there are 10.0-15.0 volts, ensure that engine is mechanically sound and fuel
system is operating properly,
If there are 22.0-28.0 volts, perform step 3.
If there is no voltage, perform step 4.
Step 3. Disconnect each glow plug lead and check for resistance between glow plug terminal
and ground. Resistance should be 1-3 ohms. Check glow plugs for looseness or
damage.
If any glow plug does not have correct resistance or is damaged, replace, (See
paragraph 3-20) Tighten any loose glow plugs.
Step 4. Tag and disconnect all glow plug leads from glow plugs. Check for voltage between
glow plug relay terminal where red lead connects and ground.
If voltage is 10.0-15.0 volts, connect glow plug leads and start engine.
If voltage is 22,0-28.0 volts, perform step 5.
If there is no voltage, trace circuit back to positive terminal board. (See wiring
diagram F-7 or F-8)
Change
Minister956
Florida
Okay, the multimeter was jumping from .2 and .3 ohms, unfortunately my fluke doesn't read hundredths.
Resistor may be hot. Use care when performing this step or injury to
personnel may occur.
Step 5.
Step 6.
Step 7.
Step 8.
Disconnect batteries, pull out bracket and resistor assembly (see paragraph 4-44,
REMOVAL, step 4), disconnect output (red wire) from relay, disconnect input (blue
wire) from input to resistors. Connect positive lead of multimeter to blue wire;
connect negative lead to red wire. Check resistance between resistors and ground.
Resistance should be 0.28 ohms.
If resistance is not correct, replace resistor, connect glow plug leads and
perform step 6.
If resistance is correct, connect glow plug leads and perform step 6.
Check for voltage between glow plug relay terminal where pink/black lead connects
and ground.
If there is voltage, perform step 7.
If there is no voltage, trace circuit. (See wiring diagram F-7 or F-8)
Check for voltage between glow plug relay terminal where light blue lead connects
and ground.
If there is voltage, perform step 8.
If there is no voltage, replace glow plug relay. (See paragraph 4-8)
Check for voltage at light blue lead on glow plug module.
If there is no voltage, trace circuit (See wiring diagram F-7 or F-8)
Electrical Troubleshooting malfunction #15.
2-65.0/(
1,192
Have you measured each GP for ohms?
1,192
Do you recall the readings?
Minister956
Florida
I took the GP's out and they were wet with diesel, the reading on them were less than .1 ohm. They looked very good.
I just got back from Auto Zone, they tested my batteries. The front battery (NAPA Commercial) was no good. The battery near the firewall was (newer Napa Commercial) 79%.
1,192
They need to be 1-3 ohms. Less(as yours are) is not good.
1,192
This is from paragraph/step 19,
damage.
1,192
Did your GPs have the original 3/16 wide connectors still, or have they been changed to standard 1/4" wide female blade terminals?
Go get yourself a set of AC Delco AC60G glow plugs and new connectors(if you have original terminals still), and I bet your all set.
After that, we have a few modifications that I really recommend you make, to be more reliable.
