Hey guys, Im new here so bare with me. I need help, my deuce wont start!
charliebrown919
raleigh nc
So I had a normal day of driving and decided to go fuel up before calling it a night and just as I pull into the gas station my deuce just shut off. I tried to crank it back up but had no luck. I had about a quarter of a tank and put another two gallons in the tank from a small container just to make sure. I tried cranking it a few times but had no luck. I decided to leave my deuce at the gas station and go back in the morning. Any ideas or suggestions? Any help is greatly appreciated.
rchalmers3
Half a mile from the Broad River
30
Irmo, South Carolina
My suggestion is to fill the tank, loosen the injector lines at the injectors and crank it over till the loosened lines are spitting fuel. Then close them up and see if it lights off.
Do you hear the in tank pump running with the power switch on?
Rick
charliebrown919
raleigh nc
Ill definitely try that. I would go tonight but I dont wanna drop a bolt or nut and not find it. I think I can hear the pump when I try to crank it. I think Im gonna need a friend to come with me for an extra set of hands and ears. Thanks for the suggestion rchalmers3!
jamawieb
556
Ripley/TN
Try filling it up, there is a pick up tube on the fuel pump housing that is known to fail. If it cracks or splits above your fuel level it won't be able to suck up the diesel.
Recovry4x4
LLM/Member 785
1,808
GA Mountains
You can also crack the bleeder at the final fuel filters and turn on the power to see if the lift pump is lifting.
DieselBob
15
Arnold Maryland
Going through the TM trouble shooting chart can be a big help. One time I had my deuce sitting in the driveway idling just like normal, no missing, no surging, nothing out of the normal and it just died like I had pulled out the stop cable. I could hear the in tank pump running so I opened the bleeder on the secondary/final fuel filters and nothing. Changed the primary filter and was back in business. And welcome to the site.
m16ty
218
Dickson,TN
Like everyone has alluded to, you ran it out of fuel. The in-tank pump won't pump right off the bottom so you can still have a couple of inches in the tank and run out.
First thing to do is open the bleeder on the filters, turn the power switch on, and get a good stream of fuel coming out of the bleeder. It's very likely your truck will then start after a little cranking. If not then you'll have to break the lines at the injectors and bleed it there also.
There is a chance your in-tank pump isn't working. Most deuces will run without the in-tank pump working but if you run out of fuel it will never pick it back up. If you can't get fuel up to the filter bleeder with the power switch on, it's likely your pump isn't working (you should also be able to hear it running standing beside the tank). If the pump isn't running check to make sure you have power to the pump and then check the fuse (located under a cover on top of the pump).
m16ty
218
Dickson,TN
The hose is after the pump (it's a pressure hose, not suction).
charliebrown919
raleigh nc
Thank you so much guys. Ill definitely will download any TM I can and try everything you guys suggested till I get it right. Awesome site and quick responses. Thanks guys!
