M1009 Rubber seals and such...Good Vendors?
Asmoday
Los Angeles, CA
Where is everyone picking up there weatherstripping and seals these days for items like the seals for the rear shell, door seals, windows, etc. for the M1009?
Best quality as well...:)
Thanks!
Mainsail
1,801
Puget Sound, WA
If you're doing the seals around the top, here's a cheater:
Classic Parts. Here are the four seals:
01-817 (1976-91) Blazer - Body Side Seal - Le1 $29.95
01-818 (1976-91) Blazer - Body Side Seal - Ri1 $29.95
01-813 (1976-91) Blazer - Upper Header Seal -1 $34.95
01-814 (1976-91) Blazer - Upper Header Seal -1 $29.95
Infidelm1009
Hacienda Heights CA
Just went to The Truck Shop in the city of orange to pick up parts for my 66 Chevy and found out that they have a parts catalog for 73-87 full size Chevy trucks and 73-91 blazer and suburbans
Sharecropper
1,239
Paris KY
Most of the vendors that offer replacement rubber for these trucks procure the stuff from Chinese repop manufacturers. The window channels seem to work OK, however the vent window rubber and windshield rubber is way too big. The only way to make the windshield rubber work is to cut it in two and remove approximately 4 inches, placing the joint at the bottom center. When I restored my M1028, I did not want a joint which could possibly leak, so I searched online and found a new OEM old-stock rubber from an obsolete parts vendor. This GM windshiled rubber fit perfectly. Regarding the vent windows, I fooled around with trying to replace the rubber for about a week, and finally threw the things in the dumpster. I wound up purchasing new GM OEM vent window assemblies from one of the obsolete parts vendors which specialize in such parts. I believe I posted these GM part numbers soewhere in my rebuild thread.
Hope this helps.
lindyp38
ulster county ny
my lmc truck windshield rubber is to big......im concerned about cutting the seal up.......do u have that contact info for the correct seal? thanks mario
