JamieM1009
- 0
- 6
- UK
I recently replaced the radiator in my M1009 & all seemed to go well. I've bled the system and had it running fine with the blower nice & hot and just a little bit of water going in to the expansion tank. Then i changed the temp sender unit & installed a gauge on the dash. Since doing this i've had a couple of moments where the blower was cold but the gauge rose to over 220 Degrees and then suddenly the gauge dropped to 180 & the blower went hot as it should be. It also pushes some water out in to the expansion tank but not loads. Once its done that the heater stays warm & the temp reads as it should with it sitting around 185 degrees and doesn't overheat at all.
Can anyone help me to figure out why it would do this? It seems like its sucking in some air and then once the stat opens the water circulates correctly and the air is expelled in to the tank with some of the water.
Should i have used some tape on the thread of the new sender unit? Could it be sucking the air in from there?
The trucks runs perfectly & starts perfectly apart from this issue its all good.
Any help would be great
