kabar1
- -1
- 0
- Cleveland Tennessee
just wondering what the radio power bus can be used for besides a radio?![Banana :naner: :naner:](https://www.steelsoldiers.com/images/smilies/banana.gif)
what would be the process to convert to 12 volt? I searched for a hr and couldn't find a post on any suggestionsJust about anything you want. They are 24v in the stock configuration (you could convert it to 12v, I think antennaclimber did a write-up on how to do that, and if I remember correctly, there was some discussion of uses for the power bar). You could add some power outlets or inverters for the back area of the truck. Stereo/HAM/CB stuff. Or a blackmarket electroshock-therapy booth...![]()
I did find that thread after some digging and a poke in the right direction haha, how do you utilize the actual bus , to power outlets ? After the 12v mod
Assuming you understand basic electricity concepts.Once you have a good source of power to the rear, you can wire in most anything you want.
Karl
I have a basic concept of electricity , you post things to learnJust a word of advise. If you do not have a grasp on electricity, voltage and current, it may not be a good idea to mess with the power bar/bus.
If your truck has the rear power bus it is 24v and directly connected to the batteries. No fuses, fusible links or any type of protection.
Have you ever seen a direct short with 24v? It makes quite a fireworks show. People even use it to weld stuff. http://www.steelsoldiers.com/showthread.php?79463-Welding-with-24-volts
Not trying to be mean or anything, just trying to possibly save a life or a vehicle.
I assume it would wire directly to the power bus and would provide 120 power right?
What I'm trying to do is run 120 outlets out of the back
Nope. In the DC world, that's pretty much it. You have hot & ground. No neutral to confuse the issue, no phases to worry about.All the inverters I've looked at only have one red and one black , would that even matter?
