CUCV M1009 External spare tire mount
gt1009
st.charles,IL
If you make those, count me in for one. That spare tire inside takes up too much space for me. How much do you think it would cost to get one made?
Mike_Pop
NJ
I'm working on prices for the steel. It won't be until another month when I can make a few of these. I'll get a rough price, get back to you and take some orders. The rack that I have is holding a 33" tire and if were to make them, I would make sure it can accomodate a 33" tire and a feul can. Actually, the original fuel can holder was a little different. It was a piece of angle iron that the US fuel can would rest on. But being that I like the European cans because they don't leak, I cut mine off and added the US can holder. The European cans do not have a lip on the bottom.
Mike Pop
gt1009
st.charles,IL
I would someday like to put bigger tires on my truck. Would it be possible for you to make one that would acomodate a tire that size (35 or 36")?
steelsoldiers
3,962
Charleston, WV
Make sure you add some reinforcing on the inside of the body where it mounts. I have seen some civi carriers rip right off the body after stress cracks got the best of the mounts.
BKinzey
Hollywood, CA
X2. Looks fairly lightweight to me. The problem of that type of mount pulling out of the fender is well known. A 33" tire is probably pushing it's limits and I'd definitely be concerned about putting a larger tire on it. A bumper/frame mounted tire carrier is the way to go. :wink:
Mike_Pop
NJ
I put additional steel on the inside of the truck where the tire rack mounts. I'm not totally crazy about mounting to the corner of the truck and wold prefer a bumper mounted rack as well. However, the M1009 bumper is not very strong. Having the step bumper is much stronger but it takes time to mount a step to the M1009.
Somemedic
Hobart, IN
Mike, can you send me the pics of how the rack mounts to the bumbper/body? My buddy has the means to weld and a tube bender.I know he could make a proto, jig it, and then knock out a few of these for us.Need to see where it mounts and a close up of the hinges
superburban
SL,UT
Let me know on the price. I would be interested in one for my Suburban, if I can afford it. The spare tire carrier inside is full of a WVO tank!
Mike_Pop
NJ
I'm not crazy about this design so when I get to my friend's shop in Albuquerque, I will put something together that will be a little stronger and better supported. Maybe even hold two fuel cans. I'll know better on a price with a better design.
jdeoliveira74
wilmington nc
Here are some pics of a civvy tire rack that I picked up. I'm thinking of making some of these at my friend's shop. He's got a tubing bender. If anyone is interested, let me know.
Mike Pop
Hey
did you put the m1008 bumper on your m1009?? I was debating doing that myself?? Can you take a few more pics?
thanks
Jon
360
southern ca
Hey
thanks
Jon
Do it! I swapped out bumpers and it's one of the most practical mods I've done to it. You need a welder and either a cutting torch, plasma cutter or angle grinder but pretty simple. Just understand you will be cutting the frame rails back and it's smooth sailing. badb1581-6c83-4d95-88b7-648bdb448602_kindlephoto-22873822.jpg
