JCole
- 0
- 0
- Vancouver, BC
I need to know what sort of pressure is required and how easy it is to shift into low and high range. I need to build a linkage to pull the rod at the transfer case in/out, but I need to know the force before beginning a design.
Reason being, I have a cab-over tilt up cab, so the normal lever through the floor won't work. Has to be a mechanism that can be detached so that the cab can lift.
