Stonepicker1
- 100
- 63
- Coconut Creek, Florida
You guys are tracking my MV' very closely...lol
Good info.
Good info.
Better than Ancestry.com.You guys are tracking my MV' very closely...lol
Good info.
http://www.steelsoldiers.com/showthread.php?68750-CUCV-II-2000-Crew-CabInteresting back ground on the truck. Good thing you didnt have to go all the way to Cali to get it.
...yeah, and still be able to outbid Phil!Beautiful Truck, I need to save up for a cucv II now.
I should be done with buying anymore CUCV-II's unless it a Suburban or Blazer type with 6.5L turbo....yeah, and still be able to outbid Phil!![]()
I might just do that if I can get the oil leaks fixed. Still waiting on the title from GL.Since you can't drive the tan truck, just swap wheels for a little while.
Crankcase Depression Regulator Valve or CDR Valve for all 6.5 Turbo Diesels 92-02 and 6.2's 88-92. The valve is similar in function to a PCV valve in a gas engine. On a diesel, the CDR valve regulates the amount of pressure or blowby from the crankcase back to the intake thru the turbo. This is a maintenance item and should be replaced every 30K miles as recommended. 6.2/6.5 diesels need to run a slight vacuum in the crankcase and this valve regulates that.Help me understand. What does the CDR have to do with oil pressure?
