There was not any numbers on the passenger side inside of the bolt heads which you put a red square on.Gasser conversion for sure. Has the narrow gauge cluster. You say no data tag on axles? That makes perfect sense for the older trucks. Most had the numbers and dates stamped in them. Once you find these and post the info we can narrow down a build date pretty close. Check out post 33 in this thread!
http://www.steelsoldiers.com/showthread.php?3910-Deuce-Wrecker-Engine-Swap&highlight=wrecker
It has some visuals in reference to where the numbers are on the axles. This is going to be of great assistance in narrowing down your year.
Edit, note bolted bracket. Former gasser converted to multi!
