insanejecke
- 1
- 0
- Sumter/SC
OK this will be my fender build thread.
OK so when I got my m816 there's a few body parts really needing some love and care. Like my fenders they were in really sorry condition so. I decided to rebuild them one because I'm broke and two I have sources to metal like tread plate and etc..
Sorry I don't have any pic of the fender before I rebuilt it but I have after and ill post some of the driver side when I take it off.
SO first off I had to cut all the bolts from the fender to remove it. I then disassembled it and lightly sandblasted it. Manly just killing all the rust then I primed it all with self etching primer. Then I blasted all the plating after semi fabbing it up. BTW none of this tread plate is scrap its all 3/16 tick and new not sure what grade off hand. I also primed it as well.
Then long story short I welded it all up on the fender. I undercoat the bottom of the finder I did 3 coats and on top I used Dupli-Color Truck Bed Coating http://www.repaintsupply.com/prod_images_blowup/TR250-Truck-Bed-Coating.jpg
After letting it cure for one week I added the marker light. I added led bubs I used no name Chinese make bubs but there awesome and yes there 24v. The one I used for the turn light is a projected and I tested on 12v and it was bright!!!!! After that I added my headlights.
Installing the fender was fun I used stainless steel bolts with anti seize. I had trouble because were the fender slides in front of the battery box housing well I made it to big so I had to cut both the finder and the box but just a little. When I get time ill make a new pieces to go back were I cut it. I re-primed it and painted it after so I wont have to worry about rust.
And that's it for now I will update this as I move on with the other side.
please feel free to comment.
![marker lights.jpg marker lights.jpg](https://www.steelsoldiers.com/data/attachments/297/297785-ae3d0fbb959390609a7b0216171aa2b0.jpg)
![finder4.jpg finder4.jpg](https://www.steelsoldiers.com/data/attachments/297/297782-657a9f5f5024b42308a7e91b4bdbf309.jpg)
![finder3.jpg finder3.jpg](https://www.steelsoldiers.com/data/attachments/297/297781-c7b6280f16deec157a9848a2de5e7332.jpg)
![finder1.jpg finder1.jpg](https://www.steelsoldiers.com/data/attachments/297/297777-7b0e208475d441dd311d21d1b2df6aed.jpg)
![finder2.jpg finder2.jpg](https://www.steelsoldiers.com/data/attachments/297/297779-71f861bacdf0d9acc7ff0b0679001a89.jpg)
