volver
- 0
- 6
- Moline, IL.
395/85R20's. I want to run the rear wheels dish out.
Is it necessary to counter sink the bolt holes of the rim? or can I flip the nut around and have its flat side against the rim?
What prevents the rim from rotating 1/4inch back and forth when the rears are duals, just friction? I would think that the rim would spin on the hub until the side of bolt hole contacts the stud. Then if you did heavy breaking it would rotate the other direction until it hit the stud again.
