Hooty481
- 4
- 18
- Russell County Kentucky
Picked up my new to me truck from Andy in Missouri on Friday. When we got there I test drove the truck. Only thing that didn't work was the Jake brake. We did some testing and here is what we found.
Switch on the injector pump is closing circuit when the pedal is released.
Switch in the floor is closing circuit when it is pressed.
Hooked 12 volts straight to terminal on heads and Jake brake worked.
Not getting any power to wires that plug into head when Jake brake pedal is pressed.
Is there anything else that I can check. All circuit breakers are pushed in. If someone new which tm and what section had the wiring diagram it would be helpful.
Does anyone know of a relay or anything that I am missing?
