- 3,750
- 1,518
- North Carolina - FINALLY !
I forgot to mention that these replacement torque rod ends SIGNIFICANTLY reduced the amount of "bounce" that the truck had while driving. Really made a huge difference in the ride of the truck.
Yup, that weld is going to fail the first time it's tested. There is no penetration anywhere.Now you can clearly see why I always say, "just because you own a welder, does not make you a welder".
I ended up just unbolting mine. Some have said it can be done in place, but it was a PITA for me so off it came. Actually, I kind of laid it over to its side and was able to get to the upper nuts with ease.I have 2 bad Torque Rod Ends (thanks haspin rally! lol) one of them is a upper rod end. i was reading the TM, and it says to remove the spring pack so you can get to the nut.. but it looks as if you were able to do it without removing the springs? if so, how? thanks- Josh
In hind sight it would have most likely been easier to disassemble the springs out of the way, however the old nut had to be torched off and being in NY sate and the associated rust, it seemed easier (not always the best choice) to leave the spring. Putting it back together meant turning the nut at a rate of about 1/16 at a time, but it went in and sufficient tightening was possible. I used a Harbor Freight open end wrench, do not use an impact as this is a tapered seat fit and you will over stress it quickly with an impact. If it were me, and I were you, if you are going to take it apart that far, replace both front and rear uppers at both ends as they are on the same side and you would only have to remove the spring pack once in a lifetime most likely. The bottoms are easy but those two tops are def not fun.I have 2 bad Torque Rod Ends (thanks haspin rally! lol) one of them is a upper rod end. i was reading the TM, and it says to remove the spring pack so you can get to the nut.. but it looks as if you were able to do it without removing the springs? if so, how? thanks- Josh
It wasn't pretty but it allowed me to drive the truck over a hundred miles without incident. All of the force of these ends are fore and aft, and those bars only kept it from sliding back off the bushing. And they even stayed on during the press out of the old ends, so it was as the saying goes, "good enough" for a field repair.Yup, that weld is going to fail the first time it's tested. There is no penetration anywhere.
Hello, reviving this thread. When taking the spring pack apart on the passenger side of the truck. Without having to buy and make a special wrench, I think unbolting would give the best access to the ends of the upper torque rods for me. If I have the rear of the truck supported by jackstands on the axles on each side, wouldn't unbolting the spring pack cause the axles to push up to the frame, since the axles are being supported by the stands, and freeing the leaf spring from the trunnion by unbolting the U bolts from the bottom would cause the axles to raise up? Same scenario if the 4 wheels were on the ground, correct? Maybe I'm missing something here.I ended up just unbolting mine. Some have said it can be done in place, but it was a PITA for me so off it came. Actually, I kind of laid it over to its side and was able to get to the upper nuts with ease.
Jackstands under the axle. Remove the u bolts. Remove the upper lift sling bracket. It is held on by the u bolts. You can access the nut with it removed and that is it. Pack will stay together. Head of the spring pack bolt rests in a recess in the trunion. Top nut rests in the hole in the center of the lift bracket.Hello, reviving this thread. When taking the spring pack apart on the passenger side of the truck. Without having to buy and make a special wrench, I think unbolting would give the best access to the ends of the upper torque rods for me. If I have the rear of the truck supported by jackstands on the axles on each side, wouldn't unbolting the spring pack cause the axles to push up to the frame, since the axles are being supported by the stands, and freeing the leaf spring from the trunnion by unbolting the U bolts from the bottom would cause the axles to raise up? Same scenario if the 4 wheels were on the ground, correct? Maybe I'm missing something here.
Also, if I manage to get the U bolts removed, the pack is held together in the center by a long skinny bolt. Is there a nut on the bottom of this that will fall off when I remove it to remove the upper section of the pack, and be impossible to find again without completely removing all the leafs, and out of the truck, or am I missing something here also? Or does it thread into the pack or the trunnion lower bracket?
Thanks for those that are still here...
Ah I see...thank you. So you don’t even need to mess with the spring pack bolt. And the axles won’t come flying straight up. Good to know. And if you did have to pull the spring pack bolt, the nut is on top for easier disassembly. I’m assuming the head is in a hex-shaped hole to hold it in place while you remove the nut?Jackstands under the axle. Remove the u bolts. Remove the upper lift sling bracket. It is held on by the u bolts. You can access the nut with it removed and that is it. Pack will stay together. Head of the spring pack bolt rests in a recess in the trunion. Top nut rests in the hole in the center of the lift bracket.
Thank you Warren. I’m new to the 5T world. I’ll definitely take this to heart. I was only looking to remove a few leafs to get a clear shot with a BFH to pop out the threaded ends of the inserts. Removing just the carrier will get me to the nuts better. With all the airlines and stuff in the way under the truck, I’ve been successful (on a M35 at least) tapping in a wedge and then a few good hits with a BFH on the threaded ends to pop them right out on the upper dogbones.Wes nails it.
If you insist on removing the center bolt holding the spring pack together, be sure to clamp the leaf springs first...each spring is heavy & has a guidance system built in for your toes/feet/ankles. They are unwieldy at best once the center bolt is removed.
Take a good look at your U-bolts when you remove them...if they have any wear at all from corrosion, have them replaced with new ones. There are several heavy truck & equipment suspension repair places around you that can make new ones for you.
If you place blocks or jacks underneath your center trunnion, be sure that these don't crush the zerks/grease fittings on the bottom of the trunnion...not all of them are flush, and wood does compress into tiny spaces when weighed down...please don't ask me how I know.
Image or part number of the offset wrench, please?I'd get the offset wrench I mentioned. Don't have to jack anything up, remove the tires, or take the spring pack apart and off. But, I'm lazy. Did all 12 ends of all 6 rods in a single evening, with retainer plates. I didn't even pull the cotter pins, just turned the nut right through them and sheared all 12 off. Zero issues, no thread damage. You can spend days just trying to pull/drill those seized cotter pins. Plus I think it is safer this way. Truck and suspension stay together, all wheels are on, safe to crawl under, etc....
Your inbox is full. Here's the gist of my message:https://www.steelsoldiers.com/showthread.php?167166-All-5-tons-Heavy-Duty-Torque-Rod-Ends/page11
Post #103 is where I add retainer plates to the new end links before installing them, wrench is post #112.
