flyanbrian
- 0
- 0
- South Florida
Hello all,
I am new to this websiteand I wanted to say it has been a wealth of info so far. I recently purchased an MEP 005A. After cutting off the lunette ring (coudn't get it out) I welded a piece of 3" square tubing under it and installed a titan hydraulic brake actuator. Works great, tows great, stops great! I installed new fuel filters and swapped over to a spin on oil filter. When I tried to start it, it would start and run for about 30 seconds then die. You guys really understated the importance of the little glass check valve! Once I drove it out and cleaned it up the genset started and ran great! After flashing the field the output came upnto 240 volts. Forgot to mention I did the single phase conversion too. I walked around it and checked for leaks but when I got back to the control panel the output was zero. Now when I flash the field the output comes up but goes away when I let go of the switch. I am about to pull the manuals and get into it but I was hoping somebody would kow the problem right off hand.
Anyway, thanks for all the good info.
