M1061A1 ...Recovered
Recovry4x4
LLM/Member 785
1,817
GA Mountains
The M1010 isn't getting anywhere near this thing. I think I have a suiter for it. Now I just have to devise a plan to get it to the GA Rally for delivery.
Stretch44875
Super Jr. Moderator
29
Tiro, Ohio
Re: M1061a1
Don't think that is a cucv trailer... I did pull mine with a 3/4 ton truck, don't do as I do!
Take one of the brake drums off, and remember your vow of no 5 tons!
Jakelc15
36
Hanover Pa
I wouldn't want to pull one with anything less than a Deuce. A good load on it is pretty taxing on a deuce. They were made for the 5 tons. They're rated for 10k but the Army regularly put Humvees and generators weighing over 10k on them.
I've used mine a good bit, sometimes not as intended.
quickfarms
24
Orange Junction, CA
M1061a1
Interesting loading technique
I did not know they were tilt beds
Recovry4x4
LLM/Member 785
1,817
GA Mountains
I will not disclose my method of retrieving it but it will be short lived here. JW4x4 wants it for his trucktor so it shall be.
Trailboss
137
Norwood LA
The laundry unit setup on mine gives a gross trailer wt of over 15,000 lbs! 3-DAngus suggested it would make a very sturdy height-adjustable work table, especially if you took off the tires.
Recovry4x4
LLM/Member 785
1,817
GA Mountains
What's been the average price of these as of late. I'm afraid to post up what I paid for this one, don't want to get mugged.
maddawg308
734
Front Royal, VA
I owned two - they are very useful, but a deuce is the minimum you want to haul it with, as far as military trucks go. (Stretch hauled it home with a 3/4-ton pickup, but I think he was borderline nuts). Going up and down hills EMPTY on I-95 in northern VA, slowed the deuce down to about 25 on the hills. A 5-ton is preferable.
jw4x4
Dayton, Ohio
Looks like that trailer only had the front axle touching the ground when Stretch pulled it with his pickup. I am wondering about the lunette height of the trailer when behind my trucktor. It should sit level. Thanks, Kenny!!!! It's great to have good friends in good places.
