mponseigo
- 0
- 1
- New Lenox il
6.2 hard start oh09
I have been having problems with starting first thing in the am. It would start and run for about 10 sec. then die
! Thrn would have to crank for 45 sec. then would run and start all day every time i turned the key as soon as i turned the key it would start right now. after starting first thing I would have to drive for 3 miles before it would shift to 2nd gear??? The rest of that day it would shift perfect no problems? I had 19" vacuum at idle. In the process of troubleshooting she devloped a massive oil leak coming from up by the passenger side head at firewall I could not see with a mirror, So i pulled thr intake manifold off and started her up and oil was puking out of the Vacuum modulater $139.00 later, I installed next morning she started right away
! happy
No oil leak
happy happy! Then I drove her and she shifted through the gears perfect! happy! happy! happy! It has been a week driving every day shifting perfect starting perfect! Now I have a second 1986 m1009 with a hard starting issue mabey it is the vacuum pump again??? I will try soon!
No oil leak
