An Improved, Self-Made Flare Nut Wrench for IP Removal/Installation
dagsurplus
Fresno, CA
If one has to loosen/tighten IP injection lines to the IP while it's mounted on the engine, it's a knuckle-busting, hand scraping proposition. I've found that a 5/8 inch box end wrench can be turned into a 10 point flare nut wrench that is infinitely more effective than a store-bought, normal 5 point flare nut wrench. The sacrificial wrench was an extra Craftsman 5/8"; gap made with a die grinder.
jw4x4
Dayton, Ohio
Not to hijack the thread, but I did a similar mod to a wrench in order to change the power steering lines on my 1009. Came in handy on the pump.
jdknech
Jeffersonville, Indiana
if one has to loosen/tighten ip injection lines to the ip while it's mounted on the engine, it's a knuckle-busting, hand scraping proposition. I've found that a 5/8 inch box end wrench can be turned into a 10 point flare nut wrench that is infinitely more effective than a store-bought, normal 5 point flare nut wrench. The sacrificial wrench was an extra craftsman 5/8"; gap made with a die grinder.
sticky thread??
