M416-A1 & M101-A2 interchange???
bowtieman55
Elizabeth City, NC
This is my current M416-A1 surge brake/hitch setup. I want to go back to original. 20130709_200529.jpg20130709_200536.jpg The M101-A2 looks EXACTLY the same to me (in this picture). Is the surge brake/pintle and drop-down leg stand the same? Will it replace my current hack-job?hitch.jpg
MWMULES
345
DESOTO, KANSAS
I know for certain that the whole assembly will not swap and don't know if the leg will but the ring part from the 101 may. Measure it and see. 2cents
harleyhouse
30
Oakmont, Pennsylvania
You are towing with a full size Chevy tear off all of that heavy crap and run with parking brakes only. Fab a new custom nose hitch mount or there is one on ebay for $75.00 that should work.
Evil Dr. Porkchop
272
Colchester, VT
The whole assembly is different, however the lunette, shock absorber, and master cylinder are the same. The landing leg is different and will not work without some modification.
bowtieman55
Elizabeth City, NC
Evil Dr. Porkchop
272
Colchester, VT
If you look at your picture of the m101a2, you can see it has the one piece landing leg. m416s have a "2 piece" landing leg (the landing leg swivel bolts to the landing leg). The older m101a1 trailers also had a two piece landing leg. The landing leg swivel is different, but the leg will bolt up to a m416 swivel, but is slightly taller than an m416 leg.
bowtieman55
Elizabeth City, NC
Gotcha. Thanks so much for your insight. On another note; if you feel that the lunette WILL work, I can get the whole surge brake/hitch setup for much cheaper than a lunette online.
Evil Dr. Porkchop
272
Colchester, VT
They share the same part number: 10632. So you can just take it out of an m101a2 and install it in your m416a1.
