No that's the whole story, I've had it going on 10 months, put 1500 miles on it running WMO/diesil mix. The only things I've done to it since Jan. other than drive it which I've done alot of is
1/2013
Install tool box
Install remote master cyl. res.
installed muffler
lubed wiper motors and compressor regulator
turned IP down 1 flat
4/2013
Removed and repaired radiator
replaced all 3 belts
repaint front black
install air scoop
5/2013
install fuse panel and aux lights
lubed air pack
7/2013
Fuel pump adjust and replace hose
I keep a log for everything I do, so I've not done anything other than drive it for a month when I started having this problem. I drive it 2-5 days a week typically, 8 miles each way, so it does more warm up and cool down than hard running. Always has ran good, just all of a sudden started any thoughts?
