lolercaust
- 0
- 0
- Hinsdale County, Colorado
Iv searched SS, TM's and every else that i could find and no luck. Im not incompident with trucks i just graduated a diesle tech school and im about to start welding school monday and my CUCV wont start. I just replaced the lift pump the armiture failed and the push rod slid off so i replaced it. I followed the TM's procedure for bleeding and it only took three cranks to bleed the new filter, then two more cranks to get it to fire BUT as soon as i let the key go from start to run the truck shut off. I craked a injector line and i got fuel, tried another and no fuel. The fuel shut off solinoid works fine clicks away with the pink wire. Do i just have alot of air in the pump or is it going bad. I dont think its going out it may be old but it only has 26k miles on it and its a very clean truck even the bottom end internals of the engine looks allmost new. any help would be great iv gota drive the truck to school monday.
