commandojd
- 1
- 8
- Deshler OH
This may be a stupid question, but what does it mean when you have to hold the gas pedal down a tiny bit to start the truck? Every time I try to start it, it wont run unless I hold the pedal down a bit...and I have to hold it for a good 30 seconds until it will run by itself. Is this normal? I have all new fuel filters and had my tank removed, professionally cleaned/ coated and re installed with new fuel. When I got the truck it had some orange fuel in it...if that matters?? I also added a very small amount of injector/ line cleaner in it before replacing the filters. It sounds a LOT better then it originally did...but I still have to hold the petal when starting it. Any help will be appreciated! thanks
