alburms311
- 0
- 0
- Hayden, AL
I installed a Sunpro Mechanical Temp gauge this weekend, AA Part No. CP8217. I used the open plug on the water pump to install the sensor using the supplied adapters, and temporarily mounted the gauge under the toggle switches inside. The gauge reads 160-165 while driving around, will dip to 120 then back up(I assume this is the tstat opening) then when I park and shut down, the gauge will slowly climb to 190-195. Shouldn't the gauge read 190-195 or a bit higher while driving?I attempted to remove any air from the system that may have gotten trapped when I installed it, which there was some, and refilled to proper level. Any thoughts?
