nosajb15af
- 3
- 0
- Akron, Ohio
Im not new to diesel mechanics, but I am new to the personalities of these trucks. Mine has a loud knock at idle mainly heard from the transmission tunnel close to the firewall. As soon as is give it gas and bring the RPMs to 1200 its dead smooth. No knock under load. Makes the knock cold or warm. Oil pressure is 40psi idle warm, 80psi revved warm. I tried pushing the clutch seeing if its the transmission, but the knock doesnt waver. Should I be concerned? I recently changed the oil and didnt notice any shavings. Next step would be to drop the pan and check bearings, but im trying not to loose 25+ quarts of decent oil. Fuel is at stock position.
Thanks
Thanks
