NMerenda
- 0
- 6
- Rochester, NY
1. On the Wiki it says only the 1028 require lsd additive. Wouldn't the 1031 also require it?
2. Do both axles get the additive or is it just the front, and how much additive do I need to add? Is it in addition to the existing fluid or is it factored into the amount the axle requires?
3. The wiki also says the axles require 90/75 gear oil, but I can't seem to find it anywhere. Is there a place I can find it or can I substitute a different weight? WEould a different weight hinder anything? And if I use synthetic fluid do I still need the additive?
