- 6,855
- 680
- Stratford/Connecticut
On the center of the timing cover on an NHC250 is a camshaft cover plate. There is an o-ring seal it says part of kit 3011472 in the tm. The diagram shows the cover then 2 shims and then the seal. I am getting some oil seeping from this cover. I called cummins support they werent able to pull anything up. Has anyone changed this seal? Did you get a cummins original seal or can I use a generic o-ring? Thanks for the help.
Will
Will
