- 1,046
- 1,877
- WOBURN. MA.
Looks the the front tires are taller, I guess you are no longer using 6x6.HEMAT behind M931A2View attachment 447287View attachment 447288
Yes they are about the size of the 16.00R20s. I just threw them on to see how they fit, Im getting the rest of the wheels blasted and powder coated.Looks the the front tires are taller, I guess you are no longer using 6x6.
Your plan is put the same tires from the front on all six? I'd like to see some photos once you bolt them on, that think will practically float on mud with those wide treads. Awesome.Yes they are about the size of the 16.00R20s. I just threw them on to see how they fit, Im getting the rest of the wheels blasted and powder coated.
NICE!with the dolly M62 or Kraz. without the dolly M54 tractor unit. (Mini Roundabouts (doghnuts) in the middle of the road here in U.K.) Are negotiated on the same side of the road as you guys! ((the right!)) The deck "rolls" out and down for loading. (pushed by the towing vehicle) and pulled back when loaded. (Gaurd at back rises as bed lowers ,drops when pulled back, acts as stepping ramp). The headboard lowers forward giving 47 foot deck.
Posts 835 '6 & '7Saw this yesterday while looking at some other equipment!
This one was in central fl from a private owner.Posts 835 '6 & '7
Where was this one? A friend of mine has just won one in PA - he's going to use the unit on his F450 for road side repairs/servicing - tractor trailers and farm calls etc. I am going to use the trailer to mount a big compressor/MEP-003/blast pot.
[SIZE=-1]Cage Code:[/SIZE]
[SIZE=-1]Part Number:[/SIZE]
[SIZE=-1]Company Name:[/SIZE]
[SIZE=-2]23834[/SIZE]
[SIZE=-2]ENG3[/SIZE]
[SIZE=-2]ELLIOTT MACHINEWORKS
INC.[/SIZE]
[SIZE=-1]MRC:[/SIZE]
[SIZE=-1]Requirement Name:[/SIZE]
[SIZE=-1]Requirement:[/SIZE]
[SIZE=-2]AAXX[/SIZE]
[SIZE=-2]MOUNTING TYPE[/SIZE]
[SIZE=-2]TRAILER[/SIZE]
[SIZE=-2]AFPV[/SIZE]
[SIZE=-2]COMPARTMENT QUANTITY[/SIZE]
[SIZE=-2]3[/SIZE]
[SIZE=-2]AGDH[/SIZE]
[SIZE=-2]WHEEL QUANTITY[/SIZE]
[SIZE=-2]2[/SIZE]
[SIZE=-2]AQLT[/SIZE]
[SIZE=-2]LIGHT[/SIZE]
[SIZE=-2]PROVIDED[/SIZE]
[SIZE=-2]AYJR[/SIZE]
[SIZE=-2]HOSE HOLDER TYPE[/SIZE]
[SIZE=-2]REEL[/SIZE]
[SIZE=-2]AZBG[/SIZE]
[SIZE=-2]ENGINE TYPE[/SIZE]
[SIZE=-2]GASOLINE[/SIZE]
[SIZE=-2]BMKR[/SIZE]
[SIZE=-2]LUBRICANT STORAGE TANK[/SIZE]
[SIZE=-2]INCLUDED[/SIZE]
[SIZE=-2]BMKS[/SIZE]
[SIZE=-2]LUBRICANT PUMP OPERATION
METHOD[/SIZE]
[SIZE=-2]AIR[/SIZE]
[SIZE=-2]BMKT[/SIZE]
[SIZE=-2]AIR COMPRESSOR CAPACITY
RATING[/SIZE]
[SIZE=-2]23.0 CUBIC FEET PER
MINUTE[/SIZE]
[SIZE=-2]BMKW[/SIZE]
[SIZE=-2]BATTERY CHARGER[/SIZE]
[SIZE=-2]BMKX[/SIZE]
[SIZE=-2]LIGHT TYPE AND QUANTITY[/SIZE]
[SIZE=-2]PANEL LIGHTS[/SIZE]
[SIZE=-2]BMWC[/SIZE]
[SIZE=-2]ORIGINAL LUBRICANT DRUM UTILIZATION
FEATURE[/SIZE]
[SIZE=-2]NOT INCLUDED[/SIZE]
[SIZE=-2]BMWD[/SIZE]
[SIZE=-2]LUBRICANT HOSE QUANTITY[/SIZE]
[SIZE=-2]4[/SIZE]
[SIZE=-2]BMWF[/SIZE]
[SIZE=-2]AIR HOSE QUANTITY[/SIZE]
[SIZE=-2]1[/SIZE]
[SIZE=-2]SR-1[/SIZE]
[SIZE=-2]MANUFACTURERS CODE[/SIZE]
[SIZE=-2]81349[/SIZE]
[SIZE=-2]NON-DEFINITIVE GOVERNMENT SPEC/STD REFERENCE[/SIZE]
[SIZE=-2]MILL10269[/SIZE]
[SIZE=-2]SR-5[/SIZE]
[SIZE=-2]DESIGN CONTROL REFERENCE[/SIZE]
