gimpyrobb
dumpsterlandingfromorbit!
- 27,786
- 769
- Cincy Ohio
Yes, anytime I mix gas in used oil, it always floats to the top.
Well, you need to look at what happens when fluids go into solution, they do not separate except under freeze distillation, or boiling them in in normal distillation practices.Uh, wouldn't gasoline be on top?? And oil would be in the bottom third would it not? I think you're off on the order of specific gravities.
http://www.engineeringtoolbox.com/specific-gravity-liquid-fluids-d_294.html
This observation violates the observations of chemists for centuries. I am inclined to rely upon my training in chemistry, my work in petroleum research, and my observations from blending gasoline with a wide range of waste oils to make diesel fuel.Yes, anytime I mix gas in used oil, it always floats to the top.
I have posted about 100 videos on YouTube that clearly show that gasoline and waste oils do not separate; however, there are frequently precipitates formed when blending light solvents with heavier waste oils. Also, the oil must be in liquid phase, not gelled, or it will not go into solution easily. Once in solution it will remain in solution unless the ambient temperatures drop significantly.I have seen the gas settle to the top in just a weekend. I am not a chemist and they might have their theorys, I just go by what I have seen and done. The gas rises to the top of the blend and the thicker oil settles to the bottom. This was in a 55gal drum we used to get us to one of the Ga rallys. It has happened other times too, but that was the most notice-able.
Details, DetailsMy latest answer to the problem has been the [SIZE=4 said:construction of a centrifuge [/SIZE]which is happily rattling away as I type. .
No, the sediments are meant to be removed, but I have found there are heavier fractions above the coke, ash and tar that can be extracted and burned during warmer months.Would you want to burn it if you could? The bottom end has all the coke, ash and tar.
No, the precipitates are not the result of a chemical reaction, but are simply suspended particles that fall out of suspension when the viscosity of the mass of the fluid medium is reduced from adding gasoline to it. One of the most important things to get about gasoline blending is there MUST be a settling period after the blend, to allow the sediments to settle out. In the case of WVO I find 1 week of settling is plenty, but 24 hours will do.@ Beyond Biodiesel, are the precipitates a result of a chemical reaction or are they the result of heavier particles settling out of a thinner mix? I am asking because I am experimenting with the feeding of a NHC 250. I mixed a batch of WMO with gasoline until the viscosity was about the same as diesel and didn't like the resultant junk that accumulated at the bottom of the container. It made me wonder whether or not my filtration system ( to 5 microns) was good enough. My latest answer to the problem has been the construction of a centrifuge which is happily rattling away as I type. That question of "will this work?" is as yet unanswered. A chemical reaction would indicate that maybe the centrifuge idea is unneeded.
Highjack away, this thread served its purpose for me. I added a 2micron filter to the end of my setup and am done now. I'll be following your soon to come centrifuge post though, and I suspect many others will to.@o1951, ask and ye shall receive, but don't want to highjack the man's thread. Am going to post up in Alternative fuels.
Thank You- I do not consider it a highjack - it seems like if it can be done at a reasonable cost, that is the best improvement he can make.@o1951, ask and ye shall receive, but don't want to highjack the man's thread. Am going to post up in Alternative fuels.
Thanks Bjorn. I was wondering where you installed this magnetic filter setup, perhaps it was listed somewhere in the threads but I didnt run across it. Did you just put it inline after the in tank pump or after the final filter and before the IP? Thanks, AaronThe magnetic fuel filter is still at work collecting metal/rust particles. These old fuel tanks are death to some metal to metal surfaces within the IP in particular.
This is as of March 20, 2013. Probably time to check it again.
