M923 receiver/hitch assembly
jester3798
blairstown, nj
I have a 5 ton 923. I was searching the threads for a receiver to install. I found and ordered the curt receiver 15605 I think was the number in the thread. when it arrived it was way to wide. I think like 40"+ my 923 needs a width of 33" max. anyone know the part number or reference for a receiver that would fit a 923. optimally it would have a 7" drop to go under the pintle but I can make it work for my application if not. thanks in advance.
jester3798
blairstown, nj
I found a new heavy duty Curt receiver hitch that should fit the deuce perfectly. I like the fact that it has some drop height so that I won't need a drop hitch adapter as tall as without it.
It is Curt part # 15605 and has a gross towing weight rating of 18,000lb, and a tongue weight rating of 1,800lb.
I just ordered one for $204 (w/free shipping) and I'll post photos when I get it installed. This is the post I found. I know it says deuce but with all the other posts associated it seemed like it would work on the 5 ton.
Bill
NightOwl
Crownsville, Maryland
Has anybody else put a receiver hitch on their m923 ? The Curt website does not give any dimensions of the receiver brackets so I'm not sure which one to order. On my truck it looks like I could attach brackets inside the truck frame at 26" or outside the beam at 34". I think the receive should drop down at least 7" from the frame. Please post photos.
bigboy44
Ava, MO.
Her are a few pictures of my build. The hitch is made of 4x4x1/4" tubing and 5/8" hanger plate with 2 - 9/16" and 1- 3/4" grade 8 bolts holding each side.2013-06-26 Civy Trailer Hitch on 5Ton 002.jpg2013-06-26 Civy Trailer Hitch on 5Ton 003.jpg2013-06-26 Civy Trailer Hitch on 5Ton 004.jpg
NightOwl
That is awesome! That's exactly what I need. If only you lived in Maryland, or I knew how to weld. Any chance you could weld up the hanger plates and tubing for me and ship it up here?
Edit: I'm guessing that many others would be interested....
TacticalDoc
26
Otisville MI
Curt part # 15605 is for the deuce? anyone find one for the M923 yet?
is there a part number for the universal class IV hitch by reese
Pahoa/ HI
They will do price matching. After a little browsing around I found a place who sold it for around 500. Sent them the link and they gave it to me at that price. I payed a little over 600 with shipping to Hawaii. Shipping to Hawaii is normally $$$$...
Moto2four
Baton Rouge,LA
Any f 250 1999-current hitch is the right size for 2 1/2 and 5 tons. Auto anything has one rated at 10k for 174 shipped
EDIT: curt part number 14041 $147 shipped to my door. Just ordered
Pahoa/ HI
Finally got the hitch mounted. Was in a hurry because I needed to use it on a job, so it's rough, and wasn't able to take pix. I need to take it apart and clean it up and paint it. I'll take so pictures then. But it works like a champ.
TacticalDoc
26
Otisville MI
M923 frame is 29 to 34 (inner / outer width)
the only factory mount I see that will fit is this - Curt 13703 Class III Receiver Hitch
it doesn't look as strong as others but for under 300 it will do
