Now we can start tracking the installation of the harness outside of the cab. On the firewall, find plugs #25 & #10; plug these into one of the circuit breakers mounted on the cab firewall (see the first photo posted by M35A2-AZ above).
**NOTE: My truck only had one circuit breaker, the other one had been removed along with the entire cab heater & blower assembly. If someone knows what other 2 wires go into the other circuit breaker, please feel free to post it below. I have 2 wires leftover that go into the missing circuit breaker, but I didn't write their numbers down as I don't have a heater nor blower assembly.** MY APOLOGIES.
The harness splits into 2 branches here on the firewall, the one with the larger-guage wires with red heat-shrink (and the horn wires, two #25 plugs) goes along the firewall behind the engine, and drops down to the frame rail there. The other branch will drop down to the driver's side frame rail, but just before it does 2 additional branches come off of this harness branch. This should be a metal plug assembly for the turn signal flasher unit (I relocated mine to the firewall) and a ground wire, and a set of 3 plugs for the headlights Hi-Beam switch (mounted to cab floor).
Refer to the second photo posted by M35A2-AZ above: the Hi-Beam plugs will go into the floor-mounted switch, and you'll have to crawl under the truck and rest up against the back of the front tire to see this. The Hi-Beam switch has the plugs arranged in an "L"-shape, the very top plug is #18, the bottom plug (closest towards the front of the truck) is #17, and the bottom plug closer to the rear of the truck is #16.
Now route the rest of this driver's side branch harness along the inside of the frame rail to the bottom of the radiator. Plug #19 will go to the Blackout Drive Light (plug in the middle of the back of the housing; the plug at the bottom is a ground wire). Looking at the back of the headlight housing on the driver's side, plug #18 will go onto the top left plug on the housing (at the 10 o'clock positon), plug #17 goes on the top right housing plug (2 o'clock position), and the bottom plug on the housing (6 o'clock position) is a ground. Ground the headlight & BO drive light to the frame rail.
Plug #25 should connect with the horn wire coming out of the steering box.
Now route the turn signal wires through the grommet hole in the frame below the radiator, and through the fender support bracket up to the box mounted inside the front of the driver's side fender (bolts/nuts that hold this box to the fender also mount the turn signal bracket to the fender). Remove the bolts/nuts holding this box to the inside of the fender, and connect the appropriate wires to the turn signal & BO lights here (#460 Left Turn Signal, #491 Parking Lights, #20 BO). Reinstall the 4 bolts/nuts holding the box & turn signal bracket to the fender.
