Great!! Thanks! I am thinking of replacing my 1854 Int with a M931A2, the bed and knuckle crane would fit perfectly on the 931, well it would be about 10" higher but I could live with that, actually I would like to find a M932A2 that would already have a hydraulic pump on the Allison, but the pump off of the 1854 Allison would also work, the big winch is hydraulic,,, this truck tried to kill me on May 5th, it ran over me, drug me through a bobcat bucket and a 12X12"X 10' timber and some other "stuff", it took 45 stitches to close the laceration in my right leg, and caused many other injuries (rolled me up like a booger!), some would say it was my fault and of course they would all be correct
, I pulled up to my shop and was going to unload a diesel irrigation pump that was on the back, jumped out leaned back in and tossed a brick on the gas pedal so the hydraulics would work and the **** thing was still in gear and took off, the outrigger behind the cab grabbed me and pulled me down and I fought it until I managed to get loose only to realize that may have been a big mistake as here came the rear wheels, I started to act like Indiana Jones grabbing whatever I could so the truck would start dragging me again when mercifully the truck ran into another truck, pushed it into a 300 gal. diesel fuel tank (full) turning it over onto it's side and everything came to a stop. I decided that that truck, no matter who's fault it was needed to go, also it is totally gutless and does not have air brakes for towing trailers, if it did it probably would not have run over me with the air brakes set.. BTW that truck belonged to some Hippie Musicians and that is a microphone on the door..
