RjSteed
- 0
- 6
- Wesley Chapel, Fl
No, 5 on 5"Are you going with a 6 lug hub to match the Tahoe?
Wish I had 6 lug
In the Army I had an M37 where someone had interchanged the RF brake drum with the LR brake drum. I had left handed lugs on the front and right handed ones on the rear!!All Budd wheel lugnuts are left hand thread on the left side, to prevent them from loosening while going down the road.
I think ill be loosing that ability when I put electric brakes on it...I wouldn't want to lower the trailer with shorter tires/wheels. The beauty of the 101 is its ability to dump. If you get it too low it wont tilt as far.
My Tahoe has 5 lug wheels not 6.Why are you not getting 6 luck hubs? The axle companies are able to put whatever hub you want on there and by going with the same bolt pattern as the tahoe you avoid having to carry an extra spare. To each his own. I would also keep the existing lunette on there and just get a pintle hook for your tahoe. Much cheaper/easier than swapping out to a ball hitch and more secure as well. There is a reason heavy duty trailers have them instead of balls for towing excavators and what not.
The M101a3/M116a3 had a crank landing leg on the front and that swaps out for the existing landing leg with 1 bolt. Very worthwhile swap. Otherwise and crank landing leg from Tractor Supply can be bolted onto the tongue and you can just leave the existing leg there for added security.
