How can I put a MT643 in my M35A3?
welldigger
Benton LA
If I had to guess it won't fit unless you move the transfer case back. Then your in custom territory. Isn't the final drive 1:1 in the mt643? If that is the case then there isn't much benefit to retrofitting it in.
ShrekA3
Aliquippa,Pa
My trans died so I've found a brand new MT643 on the cheap. I've heard it's supposed to be a superior trans. Just don't feel the 1545 is worth rebuilding due to its numerous complaints of reliability in the A3. Allison guru said 1545/545 are overloaded in a Deuce. Everyone claims MT643 is the trans to go to but I want to now how it's done.
ShrekA3
Aliquippa,Pa
I agree the that the final drive is 1 to 1 and may have to move the transfer case. I'm wandering if the juice is worth the squeeze?
welldigger
Benton LA
If you haven't already purchased the transmission and are willing to take on moving the transfer case then I suggest finding something with an overdrive. Otherwise you will be going through a lot of trouble for not much gain.
steve6x6x6
Winter Haven, florida
The 1545p has a lockup converter, the 545 does not, it is not really 1:1 it has 7% slipage. Your 1545p top speed is 52 to 53, you will have 7% less with a 545 or mt643.
ShrekA3
Aliquippa,Pa
A bit off course here guys. I need to know if anyone out there has put another type of tranny in a A3? I have a MT643 available which is very close in size and can handle more power, torque, and GVW than the 1545 or 545. This is what I have to work with. Please help
welldigger
Benton LA
You have to understand that the prop shaft is already so short that without moving the transfer case backwards there isn't room for any bigger of a transmission. This very topic has been covered numerous times.
Bear in mind, moving the transfer case is no small task.
porkysplace
1,496
mid- michigan
Ok so you have a cheap transmission that will need alot of fab work along with 3 new driveshafts . Price out the driveshafts , material to move transfer case ect. ect. , time and the fact that parts will no longer be common to other trucks . I think you will find you are puting less money for this used tranny to start with , but will spend more in the long run with alot of downtime.
11Echo
96
CT W. R.
The Canadians had good success with the MT643 behind the Detroit in their deuce trucks.
