- 144
- 17
- 18
- Westminster/MD
Anyone have any experience in adjusting oil flow-pressure?
My M35 apparently has long term wear on the bearings; when the engine starts up I get about 35 lbs. at idle, after running for about 15 minutes it drops off to 3-5 lbs. at idle, this is all indicated on a mechanical gage. I get about 12 - 15 lbs. while running and shifting gears.
I have a gov. rebuild engine but have not made time to switch it out. Looking to make one last run for the Memorial Day parade in my hometown before I switch out the engine this season. I'd like to boost the oil flow to protect the bearings so I can have a rebuildable engine core.
I did the Tonka oil cartridge switch about 3 years ago, that has helped in getting oil to the bearings faster than the OEM system and has probably prolonged the engine life.
Any guidance will be greatly appreciated!
Thanks, Tom
Thanks, Tom
