Or, it's something as simple as a loose/rotten vacuum line.or your vacuum pump is toast. As it happened to me.
Yes, it could be that.Or, it's something as simple as a loose/rotten vacuum line.
true...The TM 9-2320-289-20 tech manual has sections that cover your transmission problems.
available on steel soldiers or do I need to purchase it online I do not have a manual that came with the vehicleThe TM 9-2320-289-20 tech manual has sections that cover your transmission problems.
No i have not..not real sure how...no means a mechanic..is there a simple way or a special tool needed?Have you checked the vacuum pump behind the airfilter?
since the pump hasn't failed. I would suggest to get a vacuum gauge and go through the steps of the TMOk...Put my finger over the rubber hose connected to the vacuum pump after removing the tee...their is suction. Not sure how much is good however..When placing my finger over the hole, upon removing I get s slight popping whistle sound..but definitely a noticeable amount...
Does this leave the REGULATOR as the source?
Hate to change a ton of parts and not get to the source. Mayb I should just take it to a mechanic?
