jwesley74
- 8
- 18
- Englewood, FL
I tried searching threads but didn't see any answers to this issue. I'm sure someone can point me in the right direction. Weird issue. Truck is a 1983 M925 ran/drove great. Parked it and an hour later went to drive it and the parking brakes wouldn't release. Even using the Spring Override all I hear is air dumping in intake. If the park brake is on it builds pressure. If I release parking brake I hear it dumping in intake. Checked all glad hands were closed. In fact we used an external source to build air with truck off so we could search for problem. Because it was running driving normal then this happened after being parked leads me to believe its an air release relay or valve that is stuck open. Any suggestions where to look?
Ultimately we had to cage the parking brakes and zip tie the parking brake air switch up so it would stop dumping air. The service brakes worked to drive home.
Anyone have this issue and fix or have the solution would be greatly appreciated.
