ATPTac
- 3
- 16
- Charlotte, North Carolina
So its getting about time for us to start doing some work/repairs to our Deuce. I'm kind of anal when it comes to doing work the right way and making sure that everything that needs to be done is done in one swoop. That being said, I plan on tackling the brakes first. Once I start going into the brakes and pulling hubs off I'm wanting to pretty much replace everything that's inside there within reason. So far here's what I'm planning on replacing, and if anyone sees that I'm missing anything (particularly seals) please let me know:
All 6 wheel cylinders (just got 6 new NAPA ones for free
All rubber brake hoses with steel braided
Master cylinder
Air pack (or rebuild)
Both front axle boots (going with silicone)
Lock washers
Debating on replacing wheel bearings, but definitely repacking them
Any and all axle seals... Which brings me to a few questions: From what I've been told there are 4 outer seals (are these the paper ones on the rears that I've read about?), 6 inner seals, and 2 seals for the front axle. I called White Owl and they offer the 2 front ones with and without retainers, which option should I go with? And are there any other seals I need to replace or does that pretty much cover all of them?
I'm also toying with replacing all the studs/lug nuts while I'm doing this, is that overkill? I've just seen one too many threads/pictures of broken studs, fortunately with no major accidents.
Clearly I have no idea what condition the shoes and drums are going to be in until I get in there and see, I'm not really wanting to replace any of that due to cost unless its absolutely necessary. I do have a leak coming from my right rear most axle, I'm hoping it hasn't contaminated the shoes too badly.
Does anybody have any other suggestions of things to replace while I'm doing all this? And also where is the best place to buy GOOD quality parts (namely the master cylinder and seals)? I called White Owl and got prices on most of this from them, and from what I understand they're one of the better places to deal with as far as getting quality parts go.
I'm going to be using this thread as a record of what I'm doing to the truck in the future as well.
Thanks in advance for any insight!
Jeremy
![Smile :smile: :smile:](https://www.steelsoldiers.com/images/smilies/icon_smile.gif)
Master cylinder
Lock washers
Jeremy
