Source for New OE Floor Mat?
Warthog
229
OKC, OK
pickup or blazer?
Aftermarket is the only option. GM hasn't made these parts for a long time.
renovate7
Florida
Thanks for the info. I ordered a catalog from LMC. Any idea how good their fenders are compared to OEM? Also looking for an OE grill, any sources for that?
Gripy
Los Angeles, CA
I just bought sheets of rubber and cut them to size and used spray can glue to fix up my floor. Then i gave it a spray can bed liner to make it more gripy.
Hollowman
Cleveland, Ohio
I bought a full vinyl floor liner kit from Stock Interiors last year. It was and still is a terrible fit. I bought it with the jute backing and it came with two dinky pieces of jute padding, neither of which fit anywhere in the truck. I'm starting to think I ordered/they sent me the wrong one. Another thing to consider is how tight your truck is. If you have any leaks at all the water is going to run down beneath the mat and if it's not dried out, it will accelerate rusting or get moldy/smelly. My plan is to pull my $250 piece of junk liner out, sand the floor and shoot it with bedliner in the spring.
K9Vic
Fort Worth, TX
Bed liner is really the way to go to avoid all the issues of rusting floors from moisture/water. Easy to clean and looks good when done right.
Hollowman
Cleveland, Ohio
I've seen plenty of really nice bedlined projects on here and I'm itching to do the same. I'll have a project on my hands though because I already stuck a bunch of roofing underlayment down to the metal. That's going to be a real PITA to take up and then prep again. K9Vic dis you DIY yours? Any sprayed products work better than others?
renovate7
Florida
I'm getting ready to order the mat from LMC. Can anyone confirm that part number 38-2835 is correct? I talked to them on the phone and he said it is for 3/4 ton trucks but doesn't have any info that it fits 1 ton. Also says for floor shifter and or all 4 wheel drives.
