Brake fluid leak
sxviper1982
Wisconsin
I have a 67 Kaiser deuce that is leaking brake fluid from a hose by the fire wall under the hood. Looks like the line connects to the air pack. It only leaks out of it when the peddle is pressed. Bad air pack?
doghead
4 Star General /Moderator
1,179
If you are saying that BFS comes out of the vent line, then yes.
Floridianson
2,503
Interlachen Fl.
I would pull the airpack and take it apart for inspection /rebuild. Go from there there as to the shape or what you find might tell you if it's worth rebuilding.
I like new old stock if you find you need to go that way not rebuilt.
sxviper1982
Wisconsin
Do you know of a place that sells new old stock?
