Where did you find a SEMTT TM?Stereo???
i did not see that in the TM.![]()
I found it in some of Edward Snowdens documents. Highly classified equipment and very rare. The military only has a few that are mainly stored in Area 51. They are expensive to build and even harder to maintain. A few good military mechanics have been rumored to go AWAL after working on them.Where did you find a SEMTT TM?
A stereo system is an UMWO (Unauthorized Modification Work Order).Stereo??? i did not see that in the TM.![]()
That son of a..... We need a black ops team to extradite him now!I found it in some of Edward Snowdens documents. Highly classified equipment and very rare. The military only has a few that are mainly stored in Area 51. They are expensive to build and even harder to maintain. A few good military mechanics have been rumored to go AWAL after working on them.
I think the SEMTT is a WTHWITMWO in general. (What The Heck Was I Thinking MWO)A stereo system is an UMWO (Unauthorized Modification Work Order).
Well...wait... If ya design/build your own vehicle I guess you can authorize anything ya want?![]()
It's nothing impressive really. I think the head unit is only 45watts per channel. Just something to listen to on long boring straightaways. I'm hopeful it won't be too terribly loud in the cab, since the fan will be behind the radiator blowing air away from me. Also the exhaust stack is still located in the stock position, and that's behind the crane. Haven't gotten the axle in yet. Weather has been crummy here lately (rain rain rain). So I've only been tinkering on little things as I can.I don't know where you find the time. Sound system. How many amps so you can hear it. Any pics. Did you get that axle in yet? Ok. Supper secret Area 51 stuff. Stereo?? Must be for down hills or waxing.
Yup, it was tan, green, white, yellow, and rust LOL. Those reflectors were hazed over/painted before I sprayed. I plan on replacing them.I like the lights. Plus it is painted. Last I saw wasn't it multi color? Ok why is reflector green? New Area 51 reflector? Nice work.
I have the air shocks installed. We'll see when I go for a test drive. I've got the fuel solenoids installed and wired up now to replace that failure prone manual valve. I ended up having to use a relay to make it all work out. I pulled the tank selector switch and used it purely as a power switch. That switch has 12v from the accessory bar. When the switch is on, it feeds 12v to the solenoids and a 12v double poll relay. That relay swings pin 30 to 87a. Pin 30 goes now to the fuel gauge. 87a is to the right tank. When turned off, the solenoids switch back to the left tank. And with the relay non-energized, the poll swings from pin 87a to 87. 87 being the left tank. A little more cumbersome than I want wiring wise, but I wanted to keep the twist style switch since I had already installed it. (A double poll double throw switch would have been easier)It is looking real good. Did you get front end suspension worked out? I like it.
I can honestly say, I've never owned anything that is lowered. Jacked up, sure, but never lowered. (Course I have plans for a 87 Monte Carlo SS of mine.... but that more for handling purposes with control arms up front)All that is left now is to turn that puppy into a "Low Rider"![]()
Hack up that MC SS and you are dead meat!! I think one of my drivers told you that already!!I can honestly say, I've never owned anything that is lowered. Jacked up, sure, but never lowered. (Course I have plans for a 87 Monte Carlo SS of mine.... but that more for handling purposes with control arms up front)
It'll be ok. It's not getting jacked up on 30" rims or any of that nonsense. It's getting a late model 6.0 Lq4 engine, turbo, AC reinstalled, the rear is already a 12 bolt with tube control arms. Front will get tube control arms, 12" B-body rotors and spindles, springs, and other handling bits. I want something that will have an honest 600hp on pump gas that I can play around in the hills, drive to CA with the air on, or just simply cruise around with the t-tops off.Hack up that MC SS and you are dead meat!! I think one of my drivers told you that already!!
