Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
As the title states. I did do a search and have been trying to figure this one out but if anyone the part number for the two vacuum hoses I would really appreciate posting it. Thanks!
The rubber adaptor for the two vacuum hose is no longer available. No one makes a replacement. You can just attach the hoses to the Throttle Vacuum Valve. Regular vaccum hose can be had at any parts house.
Funny because I thought the same thing but I was at NAPA and they said unless I had a part number they would not be able to help me. I am going to just pull the hose tomorrow and go around and see if anyone has any that size.
9438124 used for the two inch run off of the vacuum pump is 11/32" (.344) ID
3987364 used between the tee fitting and the first straight fitting is 7/32" (.219) ID
9438381 used for the remaining runs is 5/32" (.156) ID
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
