blackout
- 0
- 1
- new jersey
is the fuel filter houseing the same off a civilian 6.2l truck like the plugs and voltatge
yes.is the fuel filter houseing the same off a civilian 6.2l truck like the plugs and voltatge
What did civilian units use the pressure sensor for? I thought that was a military (ste/ice) use only.yes.
my 87 v1500 had the same fuel leak down problem as the military ones did. i replaced the assembly with one already repaired some time ago. i looked through my pile of old units but found none any different. i dont have the truck anymore or i would check it. i have read that the newer bases did away with the sensor and the hole drilled in the base but i have not seen one.What did civilian units use the pressure sensor for? I thought that was a military (ste/ice) use only.
like i said i cant remember what my 87 had, but i just watched a youtube video of a filter change and the base on his civilian truck clearly had a pressure sensor switch. here it is, thanksYears ago I bought a brand new OEM civy filter base, looked exactly the same, with heater and water in fuel sensor but did not have provision for the fuel pressure sensor. So, Doghead is correct, only military filter bases had the fuel pressure sensor, civy's don't.
I would not install the used part with the pressure sensor installed. you will be back where you started. lots of posts about how to fix the base if you chose to keep it. you can fix your old one to. there are 3 plugs from your old unit. if you remove the pressure sensor(round looking with 2 wires. its the middle plug) and fix or plug the hole no one will ever know and your truck will not be affected in any way.i got it at the junk yard today for 10 bucks it looks the same it has the psi sender and the plugs look the same but i did not install it yet
