Hi All,
I just had both alternators rebuilt, and after less than an hour of driving, the Gen. 2 light started flickering briefly. I have checked the voltages at the batteries with the engine running - 14.9 on the front battery, 14.7 on the back battery, 29.6 across both batteries. I also tried to check the red and brown wires to the alternators with the key off, and then with key on, per Warthog's instructions, and everything checks out on Alt. 1. On Alt. 2, I check the red wire coming into the white plastic plug with the key off, and it had 12v. There is however no brown exciter wire on Alt. 2. There is just a rubber cap covering that port. I am assuming that is the way it is supposed to be?
Possibly they did not replace the regulator on Alt. 2 when it was rebuilt? The belts are tight and in good shape.
Any suggestions?
Thanks everyone so very much for all of the great wisdom that is so freely shared on this forum.
-ben
Any suggestions?
-ben
