Iggy913
- 1
- 0
- Virginia Beach, VA
I realize this has been discussed before to a certain degree, but I'm still in need of some clarification. I've got an M923A2 and I'm interested in possibly running the 16.00R20s on it. Do they fit?
With some simple math it seems like I potentially have an issue: 14.00R20s = 48" tall and 16.00R20s = 53" tall. That's a 5" difference and it looks like I only have about 4" between the tandems. When the 16.00s are mounted on wheels is their overall dimension changed so that they actually fit? I've seen some photos of trucks on this site with the 16.00s on a tandem axle truck so I have to believe I'm missing something?
Also it appears from reading previous posts that there will be a rubbing issue on the front axle if I use the factory 5 ton wheels? In order to avoid that I should run HEMTT wheels? To the guys running these wheels are you just running them on the front or are you replacing all six?
Lastly does a 16.00 fit up in the spare tire location?
Like I mentioned in the beginning, this is only something I'm considering, I'm not sure the slight increase in ground clearance is worth sacrificing the power loss. It just seems like there are a lot of deals out there on the 16.00s vs the 14.00s for new tire purchase.
Thanks everyone.
Iggy
Thanks everyone.
Iggy
