Alternator conversion harness
combat32
107
Booneville AR.
I am in the process of doing an alternator conversion on my truck using a NOS adapter harness I got from Midwest. These were originally made for converting M35 gassers to multi fuel engines with an alternator, it looks pretty straight forward and I think I have it pretty well figured out. But I was wondering if anyone else here had done this conversion with said harness, if so I would like to see a few pics if possible of how you routed all your cables to try and get some ideas, thanks in advance if you can help me out.
NDT
7,441
Camp Wood/LC, TX
If your M37 had/has an ammeter, there could possibly be an issue with using that harness, 2 of the 4 pins in the chassis harness go to the ammeter, if the conversion harness does not have all 4 pins tied together, something may not work right. This info is from a VERY dusty cobweb part of my memory, so please excuse if I am wrong.
73m819
329
gainesville, ga.
Believe you will have to change the amp meter to the newer battery condition, charging gauge, this is what was done on the 6602s that were changed to a alt.
