epitts
- 1
- 18
- Terre Haute, Indiana
Do they still make the old style large mouth Jerry cans?
Thanks
Thanks
... they are sold as "water storage" since they do not meet current federal laws for fuel storage and claiming they are for water storage is their way around the regulations.
Yes, water cans are different from fuel cans, but easttnemc's comment was that they were selling fuel cans as water cans to bypass regs with regard to fuel cans.Water cans are different than fuel cans.
I just looked through 355 items and found only one - and am still looking.I found several on that popular E*** auction site.
I would like the USGI ones, but right now I would take any kind.Make sure you get the USGI ones, and not the ones made across the Pacific pond. On the imports, the metal washer that is supposed to compress the rubber and seal the opening, is not thick enough or strong enough to actually make a leak proof seal (ask me how I know). If you get to handle the device before purchase, measure the diameter of the rubber, then pivot the clamp and measure the diameter again, but in all four quadrants (IE, directly under the clamp points and also 90 degrees to that point). 'Cheap' ones will not swell except under the clamp area, which is only about 1/4 of the full diameter.
So you just want one for show, not to use? Or should I say 'try to use' and wind up dumping half or more of the fuel on the ground!I would like the USGI ones, but right now I would take any kind.![]()
I would start with "for show" and work my up to "try to use". Given enough parts I might be able to make a less than adequate one perform adequately.So you just want one for show, not to use? Or should I say 'try to use' and wind up dumping half or more of the fuel on the ground!
Oh, now I understand which one your talking about. Don't see many of those. The type that just screw into the opening are plentiful.It must be a description thing.
I realize the topic is "Jerry" cans and that is sometimes a misunderstood term. I guess I misunderstand it. I saw all of the spouts for the "Jerry" cans on e***.
I am looking for the flexible steel spout with the rubber gasket that is forced into the threads, when you pivot a "clamp" kind of thingy. This swells the rubber washer, which seals against the internal threads.
Yes, it has been almost 15 years since I retired, but have things really changed that much. I mean we were just starting to get the plastic fuel cans and getting rid of the metal cans. (I should have kept the metal cans.)
The one I did find on e*** was the correct type, but the condition was poor.
