a68cudas
- 0
- 0
- Brookfield, Ohio
Have couple questions. I done the doghead starter relay mod about 3 weeks ago and at that time i had my old direct drive starter in it. The relay would start the old starter fine but the old starter needed replaced as it was never shimmed and was sticking every now and then. I got a rebuilt 24v gear reduction starter and hooked it up with the coorect support bracket, turned the key and it turned engine over but when i shut key off the starter stayed engaged. What will make this do this ? I did the doghead starter relay mod so that my stater doesnt run away. Does the gear reduction starter get wired the same as the direct drive starter? The gear reduction starter has only one post on solinoid for the lil wire and the direct drive has 2 post on solonoid is there a special way the gear reduction starter is wired compared to the direct drive? Could my starter relay have gone bad in such a short time? The doghead relay ran flawlessly while old direct drive starter still worked? Any help suggestions on trouble shooting my dilemma will be greatly appreciated . Thanks
