M373A2 Wheel cylinders type?
Floridianson
2,500
Interlachen Fl.
6ton electric van. I going to pull the hubs but im thinking they are Deuce wheel cylinders. Also I might need a Master cylinder. Anyone had one apart or know about the master cylinder / wheel cyl. and if the master can still be had. Thanks
RAYZER
59
sanford/florida
I just went through the brakes on my m146 (6 ton axle).
If yours are the same the wheel cylinder rebuild kits will be 1 5/8", I have several dozen nos rebuild kits if you need some! The new wheel cylinders were hard to source but their out there.
I did not rebuild my master cylinder.
Now, if your axle is different, I may have just said all this for nothing.:D
