outcast
- 0
- 1
- Kendallville , IN
I would just like to know if I could run 6 wheel disc brakes with upgrade to split brake system?
...and when you trace the lines of those split volume master cylinders, what you'll find is the large volume section at the end (i.e. closer to the front of the vehicle) is the chamber that feeds the rear drums and the small chamber feeds the front discs.... Vehicles with disc in front and drum in rear need a split ratio master cylinder to put more fluid to the discs and less to the drums.
The fluid capacity for the entire range (i.e. pad life span) is more than the drum wheel cylinder - yes, the volume of fluid in a caliper piston can be greater than a wheel cylinder. However, upon activation of the braking circuit, the caliper uses much less fluid for a given pedal push than a drum wheel cylinder.... Therefore, disc brake reservoirs are larger than for drums because OEM designers must design a reservoir for disc brakes large enough that the brakes will still function even if Joe Public doesn’t check the fluid or add a drop between new pads and completely worn out pads."
-http://www.pirate4x4.com/tech/billavista/Brakes/
Not sure witch pic you are looking at, I make everything in all the pic's i posted in this thread.Hi steve6x6x6, do you know who makes those caliper brackets the one on the left picture ? Would appreciate any help in that direction. Thanks, ALFA2.
The rear drum brakes will uses the same amount of fluid regardless of what type of shoe activation used. The deuce rear brake cylinders are not a single servo system, as there are 2 pistons in each cylinder. The difference between the deuce and a modern system is the anchoring of the shoes. The modern style allows the shoes to float causing the front shoe to apply first, then using the force of the drum to drive it into the second shoe which is applying also, then causing it to wrap back up to the first shoe again. This really puts a bind in the drum so to speak ! Basically that's how it works, if you want the whole technical jargon there are books available. The deuce system just uses the cylinder to push out both shoes at once, and of course most of the braking is done at the top of the shoes especially after there is some wear on them. But they both uses the same amount of fluid in their 2 piston design. Yes and no on the volume of fluid needed for a disc. Yes they only need a small amount to apply, but they never give all this fluid back to the master cylinder as some is used to fill the void left from the piston not going all the way back in it's bore. If you have done disc brakes before, you must remember having to push in the disc piston back into it's bore before you could install new pads.First of all, I must confess, that while a Chevy pick-up, with front discs/rear drums is not the same as a duece, there are still a few similarities. I have done a rear disc conversion, with great results.
The above posted article omits a very important factor. In the typical vehicle conversion, the rear drum brakes are the Bendix duel-leading shoe design, the duece is only a single leading shoe, there is only servo action on one shoe in each drum, thus that article is misleading, as to the nature of using it as a referance, pertaining to fluid pressure or piston travel.
What is important, is that the residual valve(s) must be removed when drums are changed to discs, and an adjustable proportioning valve be installed in the line leading to the rear brakes, in order to prevent the rears locking-up before the fronts, (much depends upon weight carried in the rear).
There is much less volume of fluid used to energize the discs, and in the conversions I did there was no need to change the master cylinder, a drum MC provides more than enough volume of fluid, but a power boost system is def needed to provide the needed pressure the calipers require.
This is probably the best layman's way to explain the difference between the two systems.Don't get "reservoir capacity" mixed up with "fluid requirments" for effective braking.
From full "on", to full "off" the discs are only moving a few thousands of an an inch.
A drum system moves a lot of fluid "back and forth" between the MC, and the WC, much more than discs, due to shoe clearence and retracter springs.
Discs reqire more pressure, but very little fluid is actually moved between MC and caliper.
Reserve reservoir capacity with discs is only needed to make-up for the faster wear-down of the pads, it has nothing to do with the amount needed to energize the brakes.
OK SP5, this thread was about being able to use the stock master cylinder in a 6 disc system. We are now entering the Twilight Zone here. Yes you are correct in the proper name of this style of brakes, but the fact I was trying to convey is that BOTH pistons move in the wheel cylinder. Now I can tell you have recently gone through "brakes 101". I remember that time well, I still had a body that worked thenAs an addition, No, the duece brakes are not duo-servo, only the front shoe has any servo, (wedgeing) action. The rear shoe is called a "trailing" shoe, and can only have any brakeing action depending upon WC pressure only.
The front shoe is actually doing about 60% of the brakeing effort.
I was wrong. I was remembering that the rearmost chamber actually went to the front circuit on most disc/drum setups - I was mis-remembering that the front chamber was the smaller, thus feeding the rear.... Mudguppy was wrong to say that the larger reservoir in a master cylinder goes to the rear drums. ...
